View LACP Port Statistics
View LACP port statistics to monitor the performance of the port.
- In the Device Physical View, select a port.
- Select Port.
- Select the LACP tab.
- To change the poll interval, in the toolbar select the Poll Interval box, and then select a new interval.
LACP Field Descriptions
Use the data in the following table to view the LACP statistics.
Name |
Description |
LACPDUsRx |
The number of valid LACPDU received on this aggregation port. |
MarkerPDUsRx |
The number of valid marker PDUs received on this aggregation port. |
MarkerResponsePDUsRx |
The number of valid marker response PDUs received on this aggregation port. |
UnknownRx |
The number of frames received that either:
IllegalRx |
The number of frames received that carry the Slow Protocols Ethernet Type value (43B.4), but contain a badly formed PDU or an illegal value of Protocol Subtype (43B.4). |
LACPDUsTx |
The number of LACPDUs transmitted on this aggregation port. |
MarkerPDUsTx |
The number of marker PDUs transmitted on this aggregation port. |
MarkerResponsePDUsTx |
The number of marker response PDUs transmitted on this aggregation port. |
